For guys that have a VF SV6 (MY15) can you please tell me what side of the Engine sump has the drain plug. Drivers side of the sump?, Passengers side?, Rear of the car side?, or front of sump. I've never attacked a SIDI Before to give it an oil change.
It's on the passenger side of the sump, very easy to see once you get under there. I use a piece of 90mm pvc pipe cut in half vertically to direct the flow of oil away from all the fixed components of the car and direct it down into the oil drain pan as the oil does come out quite fast and will coat parts of your car.
My piece of pipe is approximately 300mm long and I either just hold it in place until the oil is falling vertically or cable tie it into position.
