gingerpickle
- Jan 3, 2012
- 2
- 0
- 0
- Location
- australia
- vt commodore
traces of oil in radiator, no trace of water in engine oil and transmission oil. any ideas?
My car has been losing water over the last year. In particular, the overflow tank becomes empty after a long trip. After the last big trip I had to add about 1.5l into the radiator. After looking into over the past year could find a leak until this morning. My biggest fear was a busted heater core. I did a pressure test on the cooling system cranking it up to 130kPa and the pressure started dropping. No leaks from the hoses however did notice coolant leaking from the engine bay onto the ground. I removed the engine cover and found the water pooling in the valley. Looks like I need to change the inlet manifold gaskets. Have you done a pressure test on the cooling system?
