Oil in radiator
10_80
Donating Member
vx Commodore.
losh1971
North Tas
VE Series I SS Ute
Yes good choice of gaskets. Mace kit is quality. The LIM gaskets are the most common place to leak.
losh1971
North Tas
VE Series I SS Ute
Does your Eco have a water pump bypass hose on the front? I had an idea early Ecos had the front adapter. They can leak there as the original ones are plastic. New ones from Repco are cheap and made of brass that last forever.
10_80
Donating Member
vx Commodore.
Thanks, I'll check that out.
krusing
Melbourne Bayside 3193
I have a VY, and sounds similar
I have a milkshake in my radiator and I have purchased a full set of LIM gaskets,
Being I have a Super6, I have a bit more hardware to remove and re-fit with gaskets,
I also have a serious flat spot when its cold, and after it warms up, it runs great.
So I am guessing the LIM is losing vacuum when cold [everything has contracted],
Just a need a clear day with no interruptions to get stuck into it.
Just hope it not head gaskets,
I probably should do the Head Gaskets since I have it pulled down that far, with the other hardware removed,
But will see how it will go with the LIM gaskets.
losh1971
North Tas
VE Series I SS Ute
I'd be pretty confident that your head gaskets are ok. Pretty rare they leak on Ecos and Buicks.
krusing
I'm a Dinosaur!...I had to google what a LIM is!
You recon your a Dinosaur, no problem with that !
I am a bit older then you :rolleyes:
losh1971
North Tas
VE Series I SS Ute
I'll admit i had to figure it out a while back. Buicks like i have, don't have a plenumn like the Eco does so i normally called it a valley cover or intake manifold and not lower intake manifold, because there really isn't anything above it.
