wannaeatyourbrains
- Sep 24, 2019
- 591
- 544
- 93
- Age
- 52
- Location
- Mecca
- VZ Executive
How well did you wash it? You might just have a dirty coolant reservoir. Congealed petrochemicals can be hard to get out. You washed out a layer last time, then hot water in there melted some more.I have pulled off the plastic overflow reservoir once a couple of months ago and washed it out properly as it was full of oily sluge. Seemed to stay clean for a few days then go Bak to crap. It doesn't seem to loose any coolant from the engine either so don't think it's a head gasket, could possibly be the timing case like U said. By the condition of the car I'd say it's been flogged it's while life and barely serviced
Maybe someone before poured oil, transmission fluid or brake fluid down the wrong spout. Or maybe it had a oil in the coolant problem that was already fixed with a new radiator etc. and they forgot to clean out the coolant reservoir.
Is there oil on the rubber of the radiator cap? Or is it only in the coolant reservoir?
