Oil issues ls1
Discussion in 'VY Holden Commodore (2002 - 2004)' started by DazVYSS, May 20, 2005.
  1. DazVYSS
    DazVYSS New Member
    VYSSM6
    Hi lads just a quik post regarding oils I recently has my vy serviced and my mechanic used mobil 1 10w-30 and since driving it for 2 weeks my motor has become noisier not so much on startup but more so after its been driven and parked for some time eg 2hours when I start it again I can here gudgeon pin like noises so this weekend I will be draining my mobil 1 and useing penrite HPR15 has anyone else had similar experiences with oils. :b:
  2. BLACK346
    BLACK346 Guest
    The LS1 seems to be sensitive to oil type for some
    reason. And what is good for one, doesn't necessarily
    work for another. I have been running Mobil 1 5w-50
    for about 10,000k know and apart from some minor
    lifter noise for about 60 seconds at startup it is as
    quiet as a mouse. I would do exactly as you said
    and go back to your previous oil, although in saying
    that, If you are still under warranty straying away
    from the recommended 10w30 could give holden
    an excuse to void your warranty.
