Oil leak.
Nick C
Katherine
2007 Holden Commodore VE SS-V Manual
SS-V Manual
I got a pretty big leak somewhere, the oil level hasn’t really changed tho.
I see a leak from the bel housing I’m thinking maybe rear main seal leak?
I started after I did a oil change, sump plug isn’t leaking but oil can be seen slowly dripping from the filter. It is tight .
Any ideas where it’s coming from?
greenacc
Searching for the billion
VE Berlina
Fix the issue with the filter as that should be easy. Better take the filter off and check the seal isn't twisted or you left the old seal on the engine and now have 2 seals on there.
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Also make sure you didn't cross thread the filter
