!!!!!???oil light???!!!!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by charged6_vsacclaim, May 10, 2006.
  1. hey guys and girls ,
    for the past few days my oil light has been coming on but only when i brake once the car has stopped completly the light goes off. i checked the oil the first day and it was full. what else could this be?
  2. MrFeelgood
    MrFeelgood Blown 5.7 inch oops Ltr
    Around the traps
    VR GTS
    Oil pick up could need cleaning could have sludge blocking it when under brakes. But hey i'm no mechanic either but i have just had same problem with a car doing that.
  3. Pete284
    Pete284 Banned
    check the dip stick for the oil. if it's low, all the oil is prolly going to the front of the sump when you brake.
    Peter.
  4. Fekason
    Fekason Fekason
    Penrith NSW
    Oil Pressure Switch?
    Over my many years driving, I have had a number of these. It has always been a defective oil pressure switch.
    Worth a check. Bit cheaper than dismantling an engine as a first check.
  5. ok and how would i clean that i.e. where abouts is it located, how to remove to clean?
  6. where abouts is that located? sorry havent had this problem b4.
  7. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    The oil pressure switch will play up if the engine has been pressure cleaned - water enters the unit and shorts it out. The switch is next to the oil filter and faces forward.
  8. Famine
    Famine New Member
    VR Berlina V6
    Dude, the EXACT thing happened to me! I checked the oil, and there was NONE on the dipstick. Turned out the sump gasket was stuffed and oil was spitting out everywhere from it. So definately make sure your oil level is ok!
  9. Berlinarator
    Berlinarator New Member
    VZ SS-Z
    hey i found this on a website:
    Oil light - The oil sender unit on a VS commodore is responsible for the oil light, and an oil pressure signal to the ECM. Moisture contamination can cause the oil warning lamp to stay on until the moisture has dispersed. The oil sender units can also leak oil when fatigued, which causes a similar problem.
    hope this helps.
  10. kopper69
    kopper69 New Member
    VRII Acclaim
    If you recently washed the engine, moisture will get into the switch and cause the engine light to come on. If you stand at the front of the car, right in the middle and look down the bottom of the engine, just under the belt there is a vertial connector with 3 wires going into it. Thats the connector. To remove it simply unclip the locking panel with your finger and lift it off. If you have access to compressed air, use that to clean the connector and where you plug it into.
    Hope that helps.
  11. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    If its coming on consistently only when you brake and the oil is full (this is usually caused by low oil level since braking takes the oil away from the pickup in the sump ) you need to probably change the switch first and if it still happens connect a gauge to the sender hole and try to bring it on when you are driving. Sometimes the relief valve in the pump can stick also causing this or a broken pick up pipe sucking air when the level drops under brakes....a clogged one would cause it to happen at other times so I don't think it could be that.
  12. CHANDLC
    CHANDLC BushBasher
    TOWNSVILLE
    1996 V6 VS LEXCEN
    went to repco the other day and it only cost me $15.70 for another oil switch
  13. Clacker
    Clacker New Member
    VS Exec Series II
    How easy/hard is it to replace?
    Clacks
  14. CHANDLC
    CHANDLC BushBasher
    TOWNSVILLE
    1996 V6 VS LEXCEN
    Not hard at all, all you need is a shifter and just unplug the wire and unscrew it and screw the new one back in and thats it. it will drip a bit a oil when u do this but just have a rag there.
  15. 5600RPM
    5600RPM New Member
    VR 3.8
    If I break hard my oil light flickers on and off...My assumption is that its the oil moving away from the sensor, as its basic physics.
  16. CHANDLC
    CHANDLC BushBasher
    TOWNSVILLE
    1996 V6 VS LEXCEN
    i would be cleaning the oil pick up, i break hard most of the time and don't have that prob
  17. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Basic physics in this case means that when you brake hard, oil in your sump will move towards the front of the sump...which is where the oil pickup, oilpump and oil pressure sensor are all located. If anything, there should be less chance of oil starvation under severe braking. As Markover has mentioned, faults such as this point to a suspect oil pressure sensor. This is a lot cheaper and simpler than pulling the sump.
  18. 5600RPM
    5600RPM New Member
    VR 3.8
    Fair enough. I ahve very little knowledge of the locations of these sensors, parts, ect... Im not exactly mechanically minded. I just assumed that it was at the back, as it provided a logical explanation to the problem.
    Either way, you recon i should check out the oil pressure sensor, eh?
  19. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Replacing the oil pressure sensor would make good sense - though first I'd remove the connector and make sure it is making good contact....maybe under braking the wiring/connector moves and breaks contact causing the oil light to come on. Always go for the simpler options first.
    Most cars do have the oil-pickup at the rear of the sump and can have problems with oil surge however not the Commodore V6.
  20. Ryzza75
    Ryzza75 Guest
    Hey!
    Sorry to bring this topic back up again but I was just reading through, and I have the same problem again... however I noticed the light only comes on when I hear this weird ticking noise from the engine... is that related and could define exactly what my prob is...? I am assuming low pressure though because sometimes when i accelerate the light goes off but i dont want to seize my engine :cry:
    I will do all the check listed above. Hopefully its something minor but its the ticking noise that worries me.
    thankyou for any help in advance
