macca234
- Apr 17, 2009
- 55
- 4
- 8
- '06 VZ SS 6L
I replaced one of these just over a week ago with the exact same problem. If would work ok sometimes, then full readings one way then the other. Its just a basic sender and i can't imagine that it would be canbus. When you scan the ECU/PCM it will come up with relevant fault codes. The part is cheap. It takes a minute to fit. Clear the codes after fitting. Problem solved.
Where exactly is it? And how does one go about replacing it?
06 L76 v8 by the way
