oil pressure gauge bouncing on idle
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pow3rslave, Jan 19, 2007.
  1. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    got an aftermarket oilpressure gauge put in a few weeks back, and today (and once or twice before now) it's bounced a bit on idle, not constantly bouncing, mostly hovering on 60, then dropping to 40.
    anyone know what could cause this? blocked galleries or something? i was considering running nulon oil flush through it, but not 100%
    should i be worried? anyone had any probs like this?
  2. defa
    defa New Member
    VN Commodore
    when teh oil warms up it will drop. if you are talking about psi i would say your oil pressure is fine..
  3. immortality
    Sth Auck, NZ
    i would expect about 50psi off idle, say over 1500rpm. at idle i wouldn't expect more then 10-15psi. i'll check my manual when the old man brings it back next time
  4. burnz
    burnz dah dut dut da dah
    springfield
    VFII SS ute M6
    this sounds right
  5. pow3rslave
    eastern subs, vic
    VP 5.0L
    oil pressure is pretty much in line with the gregories advice, but what i mean is that the oil guage actually bounces, a bit like this image of a vacuum gauge except it hovers on the higher value (60) for longer between going down to 40.
  6. defa
    defa New Member
    VN Commodore
    i don't know why it would bounce but it is still good oil pressure..
  7. immortality
    Sth Auck, NZ
    that is weird, never seen anything like that, oil pressure gauges normally give a constant reading with rpm. weird
  8. defa
    defa New Member
    VN Commodore
    ya should try andother guage
  9. pow3rslave
    eastern subs, vic
    VP 5.0L
    nah it's fine at rpm, just sometimes at idle it does that.
  10. defa
    defa New Member
    VN Commodore
    i woudn't worry too much about it. you are getting more oil pressure than i am..
