Gnh81
So last week I bought a VE SV6. Had a crook oil pressure sensor when I got it so replaced it with an aftermarket part. All was good for 3 days, then got a message on the dash saying to check oil.... checked oil and all was good. Ran the car up with my scan tool and was showing good pressures, almost higher than expected. Once up to temp at idle it was dropping below the 24kpa threshold and setting off the warning on the dash. What I have read tells me I should be around 68kpa at idle when hot. Pulled the plug off the sensor and it was full of oil. Put that down to the aftermarket sensor being rubbish..... purchased a genuine item today and ran the car up. All was looking good and then eventually dropped away to below 60kpa and then down into the low 20’s again. Pulled the sensor, made up and adapter to suit and plumbed in a mechanical gauge. Long story shortened, had very good pressure at idle around 15psi. What’s going on here?????
