Oil pressure reading
pieman18
Vt acclaim
Hey guys
so I noticed a few days ago my oil pressure gauge was reading above the 5 bar line on acceleration and only dropping to 4ish bar on idle. I’ve changed the oil and filter and now it sits around the 3 bar mark at idle and fluctuates to 4.5-5 bar on acceleration.
I’m ashamed to say that before I noticed the pressure reading really high, I’ve never really taken much notice of the pressure gauge until now.
what’s the normal range during operation?
Is there potentially something still not quite right?
Car is a vy clubby
cheers guys
pieman18
Vt acclaim
Update: it now sits at 4 bar on idle and sits at 5 bar when cruising
Immortality
Staff member
Sth Auck, NZ
Oil pressures increases with revs so that's a good thing. 58psi idle and 72psi with revs, is this with a hot or cold engine and what grade of oil are you using?
pieman18
Vt acclaim
Was sitting at 4 bar when cold idling, after 20 mins or so When it’s warm it sits at around 3.5 bar idling, cruising its around 4.5 bar, so 70ish psi I reckon
Oil is Penrite 10w30 semi synthetic
Engine temp when warmed up is Less than half way on the gauge, so completely normal
Immortality
Staff member
Sth Auck, NZ
Nominal oil pressure readings are taken with the engine up to full operating temp.
14.5 psi = 1 bar
