matqld
- Jul 6, 2009
- 134
- 0
- 0
- vt/vx ls1
Hey guys, slap your 2 bob here on oil priming ls1's if ya dont mind...
I know holden uses a sealed pressurised unit to inject oil into the galleries via the main oil access bung on side of block, but i dont have one of coarse engine assembly lube was used during assembly, but the thought of shining up some new bearings before there time doesn sit real well with me..
I am thinking of maybe tryin to get as much oil down through the oil pressure censor hole prior to start, let air out shroder valve, fill oil filter with oil-n sump, then fire her up, im sure within 1-2 turns she will fire-up, then hopefully oil pressure is good (new ls2 oil pump with new o ring for pickup) So for the sake of an inocent ls1's life...... any suggestions?????????????
Im not to confident about removing fuel relay and disconnecting coil packs as normal winding over speed dont really get the oil pump-pumping and will just squish out the assembly lube prior to starting, where-as firing it up will bring oil pressure up withing seconds replacing engine assembly lube with oil.. well thats what im thinking anyways....
Its the new bearings im worried about not the lifters/rockers cam ect, they will be all good..
thanks in advance ppl's........
