Oil / Sludge
Brutus06
Earlwood
VX Executive
I was hoping someone can help me out by telling me what is the cause of the orange coloured oil / sludge in my radiator of my VX.
I'm scared of what its going to cost if I take it to a mechanic.
Pic attached.
Big-Al
Banned
Aussie and proud
VY SS 5.7 M6
oil is getting into the cooling system. probably the intake gaskets are in need of replacing.
skappascrap
Herp is for the derp.
'02 VY SV8
Inlet Manifold Gasket has decided to end its life, I was told that you should change them every 150,000ks..
Speak to forum sponsor MACE Engineering about the Aluminum type that have a life time warranty if you want to fix it yourself :)
troyzv2
se melbourne
v2 monaro supercharged
by the look of that it is oil in your coolant. it is either leaking inlet manifold gasket (most likely if your cars not over heating) or a blown head gasket.
Brutus06
Earlwood
VX Executive
Thanks guys. It wasn't overheating so I'm thinking it must be the Inlet manifold gasket. I will replace that.
How do I get rid of the oil in the coolant? Flush it all out?
Thank you.
someguy360
The Shed
Various
once you have replaced the gasket, do an oil flush and fresh oil and your set.
You will also need to drain the radiator too so you don't gum it up with the sludge (a radiator flush would be a good idea)
Big-Al
Banned
Aussie and proud
VY SS 5.7 M6
when u've replaced the problem gasket, get some radiator flush and use as per directions on the bottle.
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
You sure its not auto trans fluid? Oil cooler in radiator leaking? Thats providing its an auto.
