oil temp sender wiring
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
1995 VS Commodore v6 ecotec
yay my new oil temp gauge and sender has finaly arrived, ittl all be getting wired in tonight, how ever i want to make sure that i wire the sender up correctly!
so do i need to run 2 wires from the sender one to the gauge and one to ground or does this sender self ground and what location do i wire the gauge line to the sender? if the sender is self grounding will it ground ok on the aluminuim sandwitch adapter etc
i know its a lot of questions but i need to get this right, i cant afford to keep changing gauges and senders etc
please help!!
:bang:
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
pro plus vaccum gauge dim?
woops wrong window
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
You might have to try, it should ground ok on the sandwich plate but it may be a bit of trial and error.
immortality
Staff member
Sth Auck, NZ
the sender grounds in the oil filter sandwich adaptor mate. however i would imagine that there is a seal/gasket of some sort between the engine block fiting and the oil filter sandwich adaptor which will probably insulate it. so it may pay to run a wire from the sandwich plate to somewhere in the block if it doesn't contact the block itself properly
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
sweet ill give that a go! the problem only seems to happen when the oil sender is on, in other words, the oil is 50 degrees plus
