jacks355
- Nov 16, 2019
- 49
- 23
- 8
- Location
- Sydney
- VE SS 6L L77
Recommendations Please - on the right viscosity synthetic oil to run in L77 DOD deleted (essentially an L98 now) with 45k kms on the clock and recent cam/lifter change.
Currently running Penrite GF5 5w30 synthetic engine oil which is recommended by GMH for std spec L77 running DOD. But with DOD delete, higher lift cam and higher engine temps I believe I should consider running a better suited oil.
From cold start engine is quiet at idle - no ticking, and throughout the revs. I've noticed when engine is hot and after driving for some time, idling in traffic and warmer days I can hear typical LS sewing machine noise or slight ticking at idle. Valve train is slightly louder between 2500 - 3000rpm when engine is at full running temp. Not loud enough for me to think there's a lifter / preload or other mechanical issue. Also other people can't really hear what I do, and it annoys me. I've read good and bad things about additives in Penrite oils so want to try something new and more suitable.
Recent engine mods/specs below:
- 6.0L L77 with dod delete.
- VCM11 cam (225/232@50, 590 lift)
- Rollmaster single row chain
- Topline - Johnson Hylift LS7 spec lifters P/N a-2281
- Original GM L77 high vol oil pump (with sump bypass valve blocked off)
- Yella Terra ultralite roller rockers
- PSI beehive valve springs
- 700kms since new cam and mods installed.
- Oil pressure from idle is 55psi hot and climbs nicely throughout rev range.
