Oils ain't oils
Dazza1980
Ceduna
VT series II
What's the best grade of motor oil and brand i should use for a oil change on a '99 VT with 220000km on the clock?
itsagixa
VX SS
Try searching, 1000+ threads already on this.
HERONVY
Steel city
2003 VY2 SS
As above
And if it was me id chuck in some nulon 10w40 or royal purple 10w40
Sent from my GT-I9300T using Tapatalk 2
edals
15w60 Penrite. covered in extreme heat and 15w is rated down to -25° used for years in both my cars.
franklinfrog
www.cheapbrisbanebikes.com
VY SS Wagon 5.7 Auto Wikid Postie Bike
Anything that's on sale. Close to 15w 40 or 20w 50. Full synthetic if you want to feel warm and fuzzy inside, but truth is you probably won't notice any difference. Change it every 10000km, this is far more critical.
Grennan
Slayer of Stupid Threads
Glen Waverley, Victoria
VE SSV G8 Sportswagon
As above
Why on earth would you waste royal purple like that?
I wouldnt go anything below a 15w. Youll probably be better off looking for something around the 20w50 mark.
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Anything really. By now at least 3 owners of neglect have sealed the fate of your car.
oska
vx custom 600RR
this, it's now fully synthetic it's so good i now change at 7k intervals
spauldj308
S Pack Man
Hobart, TAS
VR S sedan 5L, VSII ute
Personally, I use Penrite, but there isnt anything wrong with the Castrol product either.
15w40, as mentioned above, should be ok. If it seems to use oil after the change, pop for a thicker blend next time around.
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
Valvoline XLD 20w50. Its cheap enough to change more regular, and will do the job. As stated, syn is a bit of a wank in a V6 with those ks.
