Oily leak from A/C compressor
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by thieled, Mar 16, 2008.
  1. thieled
    thieled New Member
    VT Acclaim Wagon Series 2
    Folks
    I've had an oily leak from the A/C compressor for many months. It appears to originate from where the two pipes are attached to the unit. I had been advised that there was a leak in the system (around this connection) & that the oily substance is from the oil in the refrigerant. Not surprising the air coming out is now not cold. Advice from my local mechanic is that the compressor needs replacing. This seems a radical (& costly) solution but I wouldn't know. Does this kind of leak require the compressor to be replaced?
    Many thanks for your help!
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Not if it is leaking from where you described. Just need to replace the seals. It is common for the seals to leak. You will need to evacuate the system first if there is any refrigerant left. That should be done by a qualified refrigeration mechanic. Then regas after replacing seal.
  3. thieled
    thieled New Member
    Thanks accentstencil.
    Is it normal to get this oily leak if the seals at the pipe connection have failed or is it more likely to actually be a problem within the compressor?
  4. accentstencil
    Eschol Park, Sydney
    Yes it is normal, because they put oil in with the refrigerant for lubrication.
  5. thieled
    thieled New Member
    Any idea about what I should pay for this job i.e. evacuate system, replace seals, refill with refrigerant? Thanks.
  6. accentstencil
    Eschol Park, Sydney
    When I last did mine I had the aircon guy evacuate and save the refrigerant. Then I went home and changed the seal (costs under $20 I think) then I went back and had the guy replace the same amount he took out and top it up. I can't remember the price but I think it was about $40 or $60 because it didn't need much extra gas. It would probably not cost a great deal more to have the aircon guy replace the seal for you. I wouldn't go to the guy who reckons you need a new compressor.
  7. thieled
    thieled New Member
    Is this a time to get the receiver dryer & Tx valve replaced as well? The car has done 104K km.
  8. accentstencil
    Eschol Park, Sydney
    I really don't know. I didn't replace any of those things and had no problems.
  9. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    Wouldnt have much gas left in the system anyway,seals r cheap ($19.80),just replaced mine(same problem) took me about 1/2 hr.Then got it re-gassed for $69..
  10. pablo
    pablo Donating member
    Was a 1997 vt v6 wagon
    When you have the system re-gassed, get the operator to inject a dye into the refridgerant, this will show up under ultra-violet light so you can easily spot the exact point of a leak in the future.
    Pablo
