You are holding it mate. The hose won't stay on properly now so you need to replace the radiator.Hi greenacc
Just pulled the clip off the hose and found this part stuck in the hose..
What’s the plastic neck..??
Regards
Well there you go, learn something every day, for the last 12 years I was thinking some dipstick changed the coolant and used green in place of the original red.Pre VZ green. VZ and onward red. Ecotec and Alloytec are totally different engines. The General knows best. Mix them and you make jelly.
That’s the v6s he’s referring to mate, the ecotec has a cast iron engine and they changed to the alloy (alloytech) engine from vz onwards your vx clubby should have the red coolant in it due to it being an alloy engine, the green coolant can cause the alloy to corrode over timeWell there you go, learn something every day, for the last 12 years I was thinking some dipstick changed the coolant and used green in place of the original red.
