One of my rocker assembly bolts broke off inside!!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by freefallin, Feb 18, 2013.
  1. freefallin
    freefallin Member
    UAE
    VY Berlina / VZ SS LS1
    I had a ticking noise coming from the engine and almost everyone i spoke to said "lifters".
    So yesterday i decided to take out the lifters and clean them. When i got to removeing the rockers, i discovered that one of the bolts holding a rocker was chipped off. The other half is stuck half way in! :(
    I guess that's what was causing the ticking noise.
    How the hell can i get it out??? Obviously, i want to get it out without damaging the threads or the block.
    I would greatly appreciate any help on this guys!
  2. kizza50
    kizza50 Member
    VX acclaim S2
    My suggestion is a drill n tap the thread again the same size, do an oil flush after without starting the engine to avoid metal particles floating around
  3. ephect
    ephect Donating Member
    VS Acclaim V6
    Have U removed the rocker to see if U can get the bolt out with ur fingers or pliers? If not, buy a set of easy-outs or bolt extractors. Its a reverse thread which will after drilling a small hole U can ratchet the remaining bolt out.
    The rocker bolts are a one time use, they stretch.
  4. freefallin
    freefallin Member
    UAE
    Yeah, i wanted to get easy out but couldnt find it here. Any other ways/tricks?
  5. Reaper
    Phect is on the money. Remove the rest of the rocker and try winding out the stub with your finger or a flat blade screw driver. Most of the time it will come right out of a machined hole in a cast iron block. No need for ezy outs what so ever. If it has lock tite or similar then give it a blast for a second or 2 with a blow torch.
    Reaper
