one of those OH **** moments (HELP!!!)
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by parkerst, May 6, 2007.
  1. parkerst
    parkerst New Member
    Oh god...this is ****ing scary for a newb like me.
    Last night while I was drivin home, i heard some strange ass sound comming from the engine so i pulled up, popped the bonnet and had a look...nothing had stopped moving, nothing was jammed, so i drove her home.
    This morning when i started it up to have a look (and do the oil etc) the ****ing belt snapped right off and something went real wrong on me.
    Right, so i've got a 96 vs and on the front there is 8 cogs lookin like this.
    The one i've highlighted in red is ROYALLY ****ed. I have no idea what it is, what it was or what it used to be but its ****ed, i can tell you that much.
    The cog or what ever it used to sit on is fine, the grove is still in the steel and there is no damage on it (the metal thing going back into the engine) but what ever used to sit on it is rooted....
    So;
    1. what the hell was that thing?
    2. Where can I get em from?
    3. what do i look for in terms of more serious problems?
    4. How do i know what belt is the right one when i get a new one?
    5. Where do i get a new belt :p?
  2. dufus
    dufus Donating Member
    rickshaw
    Tell them the year, make, model, aircon yes/no, V8/V6 ect, if you forget to mention something they will ask
    Holden, autobarn, repco, auto pro ect. even some petrol stations
  3. Spaced
    Spaced New Member
    1997 VS Commodore Exec
    check all your pulleys move find I'll grab gregories hold on
  4. Spaced
    Spaced New Member
    ok bear with my sorry no pic no scanner
    top is alternator, just below that off to the right is the tensioner
    bottom left is power steering pump
    water pump middle and crankshaft below that
    two idlers to the right of that
    a/c compressor far right
  5. Spaced
    Spaced New Member
    the one you highlighted is a tensioner pulley. Not that expensive and pretty easy to remove.
  6. parkerst
    parkerst New Member
    Right, done thanks.
    ok, so how do i get the belt back on?
    I went up to repco and got a new pulley. (the guy laughed at me and wants to know where the rest of the pulley is...because i've only got the casing of the bearing left)
  7. Spaced
    Spaced New Member
    follow the diagram i sent you and from the numbers it goes like this
    on top of number one with wavy side down, outside of number two, outside of number three, on top of number four, around the bottom of number five, on the right of number six, on the top of number seven, and around the bottom of number 8
    let me know how you go.
    parkerst likes this.
  8. parkerst
    parkerst New Member
    ok, so i've got the belt on but it doesn't seem right, its almost like there is two inches of slack that I can pinch on the belt... its a lot better though- thanks for ya help.
    which of these wheel things do i adjust to tighten the belt up properly and how do i go about doing that?
  9. parkerst
    parkerst New Member
    wait, it not on quite right but now it is, i just have to get that weird locking mechanism off that adjusts the tensioner...how do i get it movin?
  10. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    I hope these two pics help.
    88GreenVN and parkerst like this.
  11. parkerst
    parkerst New Member
    Ah all done thanks for ya help guys.
