Black_Bug
- Nov 21, 2011
- 135
- 0
- 0
- Age
- 35
- Location
- Clare, SA
- VY SV8
Hey everyone,
I'm going to have to apologize in advance for the long post.
I am having an ongoing problem with our family car's air conditioning and I've got to the point where I'm pretty well stuck. I really don't want to fork out more money for an a/c specialist so if anyone has had similar problems please let me know what you did to fix.
The Car: 02 VY SV8 (Auto)
The issues were,
1) A/c Compressor engaging but blowing hot air
2) Vent's not switching great between settings (feet, window, etc)
3) Cuts out all together when turned up to 3rd setting (then intermitted for 2 seconds when starts up again)
4) Weaker air flow than my parents car (VY V6)
What I've done
So, I took the car to an auto electrician/air con specialist who checked the a/c system over, pressure tested, etc and was found that the compressor was leaking so $1300 later I had a new compressor fitted. The air is slightly cooler but no where near what I think any air con should be. I can have it on Hi, flat out cold on a 25-30 degree day and I would never feel comfortable in it, the car never gets cold. (It also has very dark tint so there isn't much sun getting in - possibly not legal tint). They checked over the whole system, I had already checked the evaporator core (searching DIY's on this forum) which is like new. The whole system was re-gassed with new compressor, but no joy.
Going on what some people have said on this forum it could be the actuator(s) that open/close the flaps for the vents. I pulled the dash apart and followed the vacuum lines as far as i could but there was no kinks, pinches, or anything to stop the vacuum. I don't really understand the whole vacuum side of the system but from what I could tell, everything was ok.
The last issue is that when the fan is on 3 or hi, even without air con switched on it will operate for around 30 seconds before the fan stops all together and we have nothing on any setting. The relays were brownish in the centre and going on advice off this forum I replaced the relevant relays (think the blower fan, and blower fan inhibitor). Bought three relays from Sprints (who either sold me the wrong ones or all three are faulty - they were Narva). I have swapped some relays that were the same around and believe it may have fixed the fan issue, but not 100% sure yet.
I have been comparing our car to my parents car which is a series 2 vy v6. Did the series 2 have a much better air conditioner / air flow?
I will pretty well try any advice anyone gives me, don't have the cash to take it back to an air con specialist, so I'd appreciate any help.
Thanks everyone
The issues were,
What I've done
Thanks everyone
