yogi_b
- Dec 27, 2006
- 188
- 0
- 16
- Location
- Melbourne
- 2011 VE SV6
So I've cobbled together the beginnings of what hopefully will be the system for my VE S2 SV6. The budget is between 1.5-2K and the main requirement of the build is that the car looks as stock as possible! The only exposed part of the system is going to be the amp and the preprocessor, but they'll be hidden in the boot. I'm going for a single 5 channel block to facilitate that look. I went for the LC7i as it has the more advanced processing. I originally hoped to put preamp RCAs on the head units but I figure if I put that money towards a decent preprocessor the end result will be similar. The subs will hopefully be mounted on the parcel shelf in the factory mounts which I hope to pick up from a wreckers. The two subs will be wired in parallel (2 Ohm) but i do have the option of the DVC model which i can run in a parallel/series configuration (4 Ohm)
Looking for advice and opinions on the following components. Has anyone used any of the following? Any pros or cons for the following
Front Components: Polk - db6501 - 1
Rear Door: Polk - db651 - 1
Sub Woofer: Polk - MM840 - 2
Amplifier: Alpine - PDX-V9 - 1
PreProcessor: AudioControl - LC7i - 1
Harness: Scosche - VW03RB - 1
Power Wiring: Aerpro - MX004 - 1
RCA Wiring: Kicker - ZI21 - 3
Input Signal Wiring: Shielded 8 Core Twisted Pair 1
DynaMat to seal any and all holes/gaps/rattles etc.
Thanks Guys
Thanks Guys
