OT: Removing a bearing
matty88
LPG Installer :p
34
Doveton
TEXXXY: Resprayed TX3 Non Turbo
I'm in the process of taking apart a lawn edger, and one of the wheel bearings has seized onto the shaft. Without damaging the plastic dust cover, what's the best way of removing the bearing in the least damaging way? I've tried knocking it sharply and using WD40 but those methods didn't work :b:
VS Omega
VS Commodore Omega
Had you posted this in the pub it wouldn't be off topic, would it :p
If you have a pair of locking pliars and you're able to get them on I'd recommend that, they're awfully useful those locking pliars
matty88
LPG Installer :p
34
Doveton
Yeah I tried that, it's siezed onto the shaft
Shounak
The Kicking Horse
37
VX Executive S2 + XF Panel Van Project
Can you tap it away gently with a chisel or punch?
matty88
LPG Installer :p
34
Doveton
tried that also, I hope I don't have to cut it off, it's just chock full of dirt
Shounak
The Kicking Horse
37
I'm suprised WD-40 and knocking it won't dislodge it..
Maybe knock the bearing a bit harder and hold the chisel more horizontally.. Hitting the bottom of the bearing of course..
Keep hitting harder, as hard as you can without damaging anything..
jules
we like the bun
pimpin
put the shaft in a vice and belt the sh** out of the bearing using a drift against the base of the bearingto ensure you don't whack the shaft itself.
matty88
LPG Installer :p
34
Doveton
45 mins with a pair of vicegrips and WD40 worked, so much dirt and crap in there!
