Reaper
Tells it like it is.
- Aug 15, 2004
- 6,493
- 11,533
- 113
- Location
- SE Suburbs, Melbourne
- RG Z71 Colorado, 120 Prado , VDJ200, Vantage
reply to the topic, Yes life as a car enthusiast in this era, sucks!
Depends on what floats your boat. Play with older stuff that had less stringent ADR's and you can have a ball
Thessman... Our modern day cars are already @ the limit of the law/standards already and when the manufacturer tests their vehicles they are under absolute clinical conditions.
Just an example is ... that if the tyres(And this HAS been proven in independent scientific tests...) are 10psi less... it will change the amount fuel it uses and so exceed the emissions standards ===> ILLEGAL.
Last I checked, there was no law or ADR that mandated fuel usage. Emission regs are more about the composition of exhaust gases etc and are limited by parts per million (or similar).
nathanVS... ALL tunes are illegal even stock ones that have not been modified by anyone
Put it this way people, our modern ECU/CPU/EMS are learning computers so lets say if a 02 sensor if not working properly it will change the tune to accommodate for the not work 02... and so will make the vehicle, if tested, illegal as it WILL fail the emissions test.
Eh??? If your 02 sensor has failed then the car may not pass an emissions test and will be required to be repaired. That doesn't mean your stock tune is illegal what so ever.
Reaper
