losh1971
- Jan 17, 2010
- 22,365
- 21,982
- 113
- Location
- North Tas
- VE Series I SS Ute
Something weird going on the ute. A while back I overhauled the front brakes, rebuilt the calipers, new pads and new rotors. I also greased the slides really well. When I did the job the outside pad on the left was more worn than any other. I checked the pads tonight as I know they are getting down and the same pad has 2-3mm less material than the other one on the same caliper. The drivers side is fine. I need to fit new pads in a month or two but would like to sort this issue out at the same time. Should I be buying a slide kit and fit that with the new rotors and pads. If I didn't have this pad so worn I actually would have six months or more left in the brakes, and not two.
