Over speed warning
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Flic'n'tobeys, Jul 13, 2012.
  1. BuickL67LOVER
    BuickL67LOVER New Member
    Peterborough
    VTX69SLX Or VT Calais Supercharged
    Mine is a 3 window High Calais
    Model but I believe this is the same for Single displays as well.
    There are 3 different modes
    Just to get technical.
    Normal single overspeed,
    use Up / Down to adjust 5 km
    at a time.
    1-4 overspeed,
    use Up/Down to choose.
    And OFF
    With Ignition on,
    Hold Mode button to change from Single to 4 Mode.
    Hold Up and Down together to
    turn off all speed warnings.
    With Ignition off,
    Hold Mode button and turn on
    Ignition then release.
    Now press mode until you get to the overspeed menu.
    If in 1-4 Mode you will notice
    Up and Down only toggles 1-4.
    When you see one that you
    want to adjust, press both
    Up and Down together once
    and it will now let you adjust
    it in 1km steps then press
    both Up and Down once to
    save your choice Speed warning.
    If you choose 0 it will
    deactivate that memory
    position.
    I hope this helps but if you are still having trouble then you may need to replace or clean the switches.
