Overfilled the oil
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Circlotron, Aug 29, 2011.
  1. Circlotron
    Circlotron New Member
    VP Exec 5L BT1 ex cop, ex taxi
    Had a *Milton the Monster moment the other day. The oil was down to the ADD mark so I put some more in but "Whoops! Too much!" Now it is about 15mm above the FULL mark. I did this often with a 202 motor, even as much as 20mm over the mark and never had problems. Will it be a prob with a 304 motor? I have driven it about 100km since and it seems fine.
    *For those too young to remember --> Milton the Monster Show - YouTube
  2. Pickle'
    Pickle' Donating Member
    Sydney, NSW.
    VE Omega
    Lol i did this in my VR, BLEW SMOKE ####ING EVERYWHERE. Like me mean couldnt see out the back windscreen it was insane. Yes it was my first time putting oil in the car and my brother was just like yeah add a little more..... Yeah as you'd know i went a little tooooooo far :). Im not sure, but i'd guess if it seems ok it would be ok but someone will correct me for sure :)
  3. mr calais 5.0
    mr calais 5.0 New Member
    victoria
    vy s 2003
    i would drain it and refill. was it all new oil or just new to old to top up?
  4. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    Ive heard that overfilling the oil can blow seals/gaskets or something, personally id get under the car losen the sump plug til it just starts running and once u think enough has came out tighen it back up and check the level, or you could just drain the lot and put fresh oil and oil filter in
  5. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    Put a clean container under it (in case you drain off too much) and undo the sump plug. Dont drop the sump plug in the container and dont do it while the engine is warm or hot or the oil will burn you and you wont be able to get the plug back in.
    Hold the plug over the hole to controll the flow, too.
    If you do end up draining it all out, just pour it back in the top. Dont worry about new oil and filter unless its due for it anyway
  6. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    1.5 cm is bugger all. Doubt it will do anything that bad. I had mine like 3 or 4 cms over when it was leaking like no tomorrow.
  7. Morton
    Morton For external use only
    Fairstar the Funship
    Overfilled oil on the 304 can lead to frothing (wind off the crankshaft), and can lead to aerated oil being sucked up the pickup, and a loss of oil pressure.
    I would personally drain and refill for the 5 minutes it will take you, but it's your call :)
