Overheated and head might be stuffed
Slapa69
Caboolture
Vy crewman 3.8l
Help! So was driving to work looked in mirror and noticed steam coming out from behind my 03 vy crewman so I pulled over and turned off car and steam was bellowing out from under the bonnet. Split a heater hose. So replaced the hose and started putting coolant in n noticed that everytime radiator was full would drain away straight away so I investigated further n realised it was coming out the exhaust pipe. Do you think it's a head gasket or do you reckon head warped or head and block possibly cracked?
krusing
Melbourne Bayside 3193
Sound like all of the above,
head gaskets,
and/or LIM gaskets,
Motor shouldn’t be damaged, just needs some serious work on it,
Not worth getting another/replacement motor, because you have no idea what faults the s/hand motor has.
Slapa69
Caboolture
Vy crewman 3.8l
Car winds over but won't start either is there a reason for it not to start? Going to pull heads off next weekend hopefully block not damaged. Then might see if I can get replacement heads if they stuffed
wildfiremaint
VR SS , 2007 Subaru LIBERTY Wagon
Hi, please let us know how you get on and maybe post some
pics. :)
