Overheating help
Jack92
Murwillumbah
Vt 50th anniversary
Guys, vt is over heating after about 10 minutes on driving like to the red with alarms going off in pipe to the block was real hot hot while the out pipe was pretty cold changed the thermostat last nite and just topped it up with water, took it for a run this morning and the temp isn't going past the half way mark but it does still moves a bit from where it has always sat between a quarter and half way, any other ideas on what it could be, not sure if coolant has really ever been changed if I go get more and give it a flush you think it would fix it?
mpower
did you bleed the system properly?
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Did you bleed the system after changing the thermostat?
Edit: A bit slow
Jack92
Murwillumbah
Vt 50th anniversary
Bloke at auto 1 told me to just disconnect the top hose, heaps of shite came out there but no I guess I didn't,
accentstencil
69
Eschol Park, Sydney
mpower
bloke @ auto1 = bellend by the sounds of it.
Jack92
Murwillumbah
Vt 50th anniversary
Ok well now I'm trying to flush it out and the water is flowing freely through the radiator but isn't going through the block, I should be shouldn't it? Why would this be if so
accentstencil
69
Eschol Park, Sydney
Because the thermostat is closed preventing circulation so you can either remove the thermostat or disconnect the heater hoses at the engine and stick a hose where you disconnected the hoses and flush that way.
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Give the radiator core a good thorough clean while you are there.
Jack92
Murwillumbah
Vt 50th anniversary
Ok it's all done thanks guys I'm running just water through it now, will drain it all back out and re flush it again, then I gotta out the coolant in, will go 50/50 I think what do I put where but and how many litres can I put? Is there such thing as over filling it?
