JACKO4590
- Sep 10, 2013
- 32
- 1
- 8
- Location
- renmark SA
- Commodore VX SS
Ok before anyone gets up in arms like I've seen in other threads on here. This is for a burnout car that can't re registered.
Ok, so I'm planning on running my exhaust out from the extractors to the side of the car where the front door meets the back door.
What is the better setup? Don't run any cats or O2 sensors or should I have de-cat pipes with the O2 sensor plugs still in them? ATM they aren't plugged in at all and I'm not seeing any codes but the car hasn't moved more than 500m so not sure how it's going to act when I take it to an event.
Also, I'll be putting a pod filter on as where the box normal sits is where the ecu is mounted. That plug that goes into the box, is that needed?
Even if I leave the airbox wire and O2 sensors unplugged would I be looking at getting it turned to help it? Lights and beeping noises won't bother me but performance is what I want to make sure I don't strain the engine too much.
Thanks.
Thanks.
