Davew033
- Aug 14, 2017
- 6
- 0
- 1
- Age
- 73
- Location
- Hunter Valley NSW
- 07' 3.6lt ra rodeo 4x4
Hi all, have had an issue for fourteen months on cold start up. Have a misfire on no.1 on first start of the day until the engine warms up a little and you turn it off and restart again, then it is okay for the rest of the day.
This engine is also dual fuel. If you do not turn off and restart, the miss will continue on both petrol or gas until such time you pull over and restart. The engine has had new lpg cyl.heads, new timing chains,guides and tensioners, new coils, new plugs, new ecu temp sender, ecu has been sent for testing 12 months ago and just been sent back for reco but to no avail. Has also had new no.1 injector fitted, been to local holden dealer for testing and local auto electrician and also had all earths and wire harnesses checked twice.
Intake manifold rear mounting bolt was a bit loose but tightening didn't make any difference.
Can anybody tell me what can cause a miss to no.1 with P0301 code and check engine light on at cold start only? Have also swapped plugs and coils from other cylinders to no.1 with no difference. Starting to run out of ideas, hoping someone may have had this same issue at some time?
Regards Dave
Regards Dave
