PAC SWI-PS Installation?
Discussion in 'Car Audio' started by stig1, Dec 28, 2009.
  1. stig1
    stig1 New Member
    VX Executive Series 2
    Has anyone installed a PAC SWI-PS successfully? If so, what version did they use to program the device?
    I drive an 02 vx series 2 executive.
  2. scozz76
    scozz76 Member
    Largs Bay, Adelaide, S.A
    VF 2014 Evoke - VYII Acclaim
  3. stig1
    stig1 New Member
    Would a vy be the same wiring as in a vx?
    How do I find out what a vx series 2 executive car is in the states? so i can match it up with car?
  4. stig1
    stig1 New Member
    I just want to do it right, and correct without shortening the system!
  5. scozz76
    scozz76 Member
    The wire colours should be the same. It was the Brown & Black/Yellow for the steering buttons in the WH and VY.
    The VX wiring should be the same as the WH Stato (don't worry about the GTO link I posted earlier). Use version #9.
    Wiring
    Factory loom 'Brown' wire to the SWI-PS 'White' wire
    Make sure you ground the Factory loom 'Black/Yellow' wire.
    SWI-PS 'Red' to switched +12volts
    SWI-PS 'Black' to ground (same as Black/Yellow)
    If you have no luck with the version number/programming, take resistance readings between the Brown and Black/Yellow wire (press different control buttons for different resistances) and post them here. We may have to work out another version for you to program.
    You should not have any problems with the version #9, you can try version #3 but I doubt that would work.
  6. VXWAGMAN
    VXWAGMAN Member
    Wantirna, VIC
    VX Series 2 V8 Berlina Wagon A4
    I installed a PAC SWI-X in my VX.. I forget the wiring but the MODE button requires a resister to be soldiered on.. Brown wire is for the wheel controls I believe..
  7. Luke0011
    Luke0011 Car Audio Installer
    VZ Berlina 2005
    the vx doesn't have a black/yellow wire, you just need to make sure the black/white wire is earth, which it is... and if you need the commodore cheat cheat on it i can send it to you.
  8. holdenboy
    holdenboy Custom Car Stereo Systems
    Nelson Bay NSW
    VR Wagon
    I want.....please send Luke ;)
  9. scozz76
    scozz76 Member
    Yep you're right, my mistake.... Sorry.
    According to my calculations, set it for version #9
    Resistance measurements in series
    0 ohms - Vol down
    1500 ohms - Vol up
    3700 ohms - Mute
    7000 ohms - Preset Ch. Down
    11700 ohms - Preset Ch. Up
    21700 ohms - Mode
    I found the steering control wiring for the VX, I hope it helps.
  10. Luke0011
    VZ Berlina 2005
    cheers for the wiring diagram...
  11. bennylean
    bennylean New Member
    Broken Hill
    VU SS Ute
    Help anyone!!!
    I'm trying to program PAC SWI-X in a VU with philips head unit and am having no end of trouble i'm sure I wired it up properly bu can't seem to be able to program it??
    Need to know what version to go with as have tried 1, 4, 9 and everytime I go into programmming the first led light turns on but when I press steering wheel control it look like it's not getting a signal and doesn't change to the right led for the remote??
    Please any info would be appreciated!
    Thanks Ben :help::help::help:
  12. mad driver
    mad driver New Member
    australia
    VT VX
    could you plese sent it to me as im doing the same thing on my VT VX 2001..
  13. mad driver
    australia
    VT VX
    were do you put the risistor and what ohmn? all my butens work exept the mode, i think i i have the same problem, this will save me going to the auto elec
  14. Pestah bro
    Pestah bro New Member
    Wh statesman
    Your a legend. Been looking everywhere for this exact info!
    Been struggling with my wh
