Pads for slotted rotors
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by someguy360, Jan 11, 2012.
  1. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    Hi Guys.
    I have ordered a set of RDA slotted rotors for the VS and was just wondering if I can use the current set of Bendix CT pats that is currently on there or if I need pads suited to slotted rotors as the current bendix pads are only a month or 2 old.
    Regards
  2. F l a k
    F l a k Member
    Wagga Wagga, NSW
    '94 VR Exec
    I rekon the current pads should be alright since they are fairly new, just so long as they don't have any uneven wear.
    You don't need special pads for slotted rotors. I run DBA slotted rotors and Bendix CT pads.
  3. gslrallysport
    gslrallysport Active Member
    VZ AWD One Tonner
    Correct, just give the pads a light rub on some smooth concrete to freshen them up a little...
  4. Bourbonated
    Bourbonated New Member
    Newcastle
    VE SV6
    I was told by Bendix and DBA that CT's aren't compatible with their slotted rotors. Can you confirm that your pads work perfectly fine? I bought Ultimate's instead of CT's but they were cheap anyway..
