paint
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by gungazza, Aug 7, 2006.
  1. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    does enybody know if there was a recall for a bad paint job a blue gray coulor thanks
  2. gungazza
    west suburbs
    vr 1993:bang:
  3. VR_Project
    VR_Project New Member
    Bunbury WA
    MWS Improved VS Ute
    is it all faded on the bonnet hell bad?
  4. Stretchomatic
    Stretchomatic Member
    Ardlethan, NSW
    86 VL Berlina M5
    you mean this colour...
  5. kopper69
    kopper69 New Member
    VRII Acclaim
    lol do you still think you might be able to claim on it?
    This is a copy of the post by vh-holden:
    Vehicle Recall Search Results for HOLDEN VR Executive, VR Berlina, Acclaim
    Problem: FAULTY THIRD SEAT HOLD DOWN BRACKETS
    Make: HOLDEN
    Model:
    Variant:
    Executive (Series II), Berlina/Acclaim (Wagon)
    Date Range:
    VIN Ranges:
    Status: Inactive
    Defect: When the third seat is fitted to vehicles the operator may have difficulty locking the seat fully down into position.
    Consequences: This could cause injury to passengers in case of an accident.
    Corrective action: Replace the third seat hold down brackets. Parts disposal to be advised.
    Notif. Date: 10/07/1995
    DOTARS No.:
    R95/042
    Supplier Name: HOLDEN
    Campaign No.: 95-H-05
    Vehicle Recall Search Results for HOLDEN VR, VS (Up to October 1996)
    Problem: TRANSMISSION FLUID OVERHEATING AND IGNITING
    Make: HOLDEN
    Model:
    VR, VS
    Variant:
    Automatic, Towbar
    Date Range: Up to October 1996
    VIN Ranges: L645621-L979936 for V6 engined vehicles. L645621-L986809 for V8 engined vehicles.
    Status: Inactive
    Defect: Overheating of the automatic transmission fluid can occur during towing.
    Consequences: Overheated fluid can discharge from the breather tube or dipstick tube and may ignite if it contacts hot engine components.
    Corrective action: Replace dipstick with one that has a lock-seal top and reroute the transmission breather hose.
    Notif. Date: 22/11/1996
    DOTARS No.:
    R96/083
    Campaign No.: 96-H-03
    Problem: Headlamp patch harness connector corrosion
    Make: HOLDEN
    Model:
    VR, VS
    Variant:
    Date Range: 1993-1997
    VIN Ranges: Statesman VR, VS and VR Series II: 6H8VRY19URL674058-6H8VSY19HVL213857; Caprice VR and VS: 6H8VRZ19URL676992-6H8VSZ19HTL939663.
    Status: Inactive
    Defect: Right hand side headlamp patch harness connector; due to insufficient clearance to the battery, contamination caused by battery vapour emissions and/or water corrodes connector.
    Consequences: Short circuit and fire.
    Corrective action: Examine headlamp patch harness connector for heat damage or corrosion on either the connector body or terminals. If wiring insulation heat damaged replace patch harness assembly. If any connector or terminal damaged replace all terminals and both connector halves. Relocate patch harness connector away from the battery.
    Notif. Date: 15/10/1998
    DOTARS No.:
    R98/063
    Campaign No.: 98-H-03
