paintin plenum on vz v6 alloytec
sexyvz
Sexy VZ in the making.
40
Colac, Victoria
2005 VZ Executive
how would i go about painting the plenum on my 05 vz executive? is it hard to take off and what would be needed to clean it up properly so the paint would stick to it. any help would be great thanx.
heres a pic of wat iv'e done so far. i want to paint the plenum black.
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
You would need to use heat resistant paint
sexyvz
40
Colac, Victoria
2005 VZ Executive
i know i would have to use heat resistant paint. how easy/hard is it to take the plenum off? and do i have to be carefull of anything while its off or while putting it back on?
impulsive
Alloytec Racing
Brisbane, QLD
VZ Alloytec
its a 10 min job, just ensure you remove all the hoses and plugs, also you will need gasket goo for the Throttle body when you remove it
sexyvz
40
Colac, Victoria
2005 VZ Executive
ok then. thanx for that. :)
impulsive
Alloytec Racing
Brisbane, QLD
VZ Alloytec
You don't need heat proof paint, preperation is key though. Why not go to a wreckers and see if they will swap for a black one
Drawnnite
Obviously Unsensible
2000 Vs Ute
or go to a wreckers. get a 2nd hand one.
do the work to it so you can take your time.
and when its done change it over onto your car?
also post up to let us know how you go.
