painting engine bays
ari666
250,000 hits
just a quickie.
im gonna need to be painting engine bays in some RHD conversion and noticed that a lot of them seem to be a very matte finish, i.e. its almost as if they havnt sprayed any clear over the colour.
i was wondering how i would go about matching that? is it a case of mixing a bit of hardner into the colour, or just simply spraying the base coat and leaving it at that.
cheers
wildss
s.e melb
vnss
yeah hardner in the color is the way i do it
wildss
s.e melb
vnss
but dont forget about matt and satin clears
Faynt11
Feeder of Trolls
07' VE SV6 Ute
dont put hardener in the base if you're using the clear, it'll peel
Boostedn14
Wide bay
VN
just use about 40% matting base in your 2k colour, will give it a nice satin look.
Boostedn14
Wide bay
VN
It all varies really, with the paint system i use, i go with a 40% matting for a good satin finish, then again i used another brand of matting base and it needed about 60% :O
ari666
250,000 hits
wildss
s.e melb
vnss
matting agent- we mix it with clears and solids to get a satin or matt finish.
it just saves having to keep two different products on the shelf (satin and matt clear) and sometimes its just quicker to chick it into some solid color and get the finish we want.
not really sure what youre asking about the acrylic, it will always be there unless you bare metal it...
