painting
jayk
30
nowra
vs comoodore
can you sand back a car with any sander and what sand paper is best to sand back the car ????
jayk
30
nowra
vs comoodore
thank youu
losh1971
North Tas
VE Series I SS Ute
Above link is broken. Anyone confirm that it is ok to cut and buff one week old acrylic? Looking online and there are various opinions. I spoke to a bloke who used to restore cars and he said it is fine. Most threads on different forums in the US seemed to say it is ok but some people say not to do it. Where others say as long as you don't wax it, it's ok? Would really like to hear from a bloke who does it for a living. I buffed my 6 day old acrylic today and it all went fine just I had a little issue where I worked it a bit too hard and now I need to respray at 70mm x 70mm patch where it cut in to the paint, meaning I had to wet rub to get it smooth.
EYY
VS Statesman
Details on how you went about sanding?
Yes you can sand/buff it within 24 hours if the temp is right, but low temp means it takes longer for the solvents to evaporate. BUT, the longer you leave it, the better. If you can push your fingernail into the paint and it leaves an impression, it's too soft to sand.
If you've rubbed through the clear with little effort and with appropriate paper, then your paint application was too thin. I like to do at least 3 medium coats and one wet coat to ensure that there's enough material on the panel so you wont rub or buff though it.
Here's one I painted last week.
losh1971
North Tas
VE Series I SS Ute
No clear coats and I don't plan on putting any. It sanded fine with 1200. I was working the edge up near the windscreen and held it in the one spot too long and it softened the new paint. I had to wet rub it with 800 to remove the paint that had curled up. I haven't hit primer yet but the paint is no longer thick enough. I tried the fingernail trick and it was fine. I was just a bit unsure if should tackle the roof tomorrow or if I need to wait another week. I'm thinking I just worked the one area too hard and possibly should have just worked it a little and finished the edge near the windscreen with a buffing cloth and not the polisher. I was more trying to figure out if the issue was me working one spot too hard or if the paint was too soft regardless? If it is the latter then I really should leave the roof for another week and just buff the sides and tailgate. The rest of the fresh paint on the bonnet was fine, so I'm just a tad unsure whether I need to wait.
losh1971
North Tas
VE Series I SS Ute
double
losh1971
North Tas
VE Series I SS Ute
Can't see the pics are they hosted or uploaded straight to JC?
losh1971
North Tas
VE Series I SS Ute
Can see pics now. Looks good did you use two pack or acrylic?
EYY
VS Statesman
They're hosted but looking fine for me. In the pics I've posted I've just used a solid acrylic white.
1200 is too harsh imo. I always go 1500 on a soft block with PLENTY of water, then do the same with 2000 w/d. After 2000g it polishes up very quickly.
It's REALLY easy to heat the paint up too much with a polisher - never hold the polisher in the one spot. Acrylic really doesn't handle extreme temps very well. You shouldn't need to use pressure either, the weight of the polisher is more than enough. Let the polisher do the work for you.
