panhard rod?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Sep 21, 2008.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hey gonna be putting low king springs in me VS soon (solid rear) and was wondering if i needed to get a adjustable pan hard rod?
    the springs will just be your standard lows.. think it makes it sit 30 mm lower (not sl ssl etc..) i have 225 tyres on the front and rear and a 2.5 inch cat back system (if the helps....dunno if it would interfere with anything)
    cheers:thumbsup::thumbsup:
  2. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    might not need it if only going to lows. after you get the springs installed and see if the diff is in the centre of the car if not fit an adjustable one.
  3. jas98
    jas98 Active Member
    maryborough QLD
    ok yeh was thinking that...have been told i shouldn't need one that it will sit slightly off .if it sits a little off i will get one regardless if it scrubs or not
    what would a adjustable pan hard rod be worth?
