87VLCALAIS
- Feb 7, 2004
- 433
- 136
- 43
- Location
- Hamilton, NZ
- 3.8 VY S Manual, ZB RSV
I have problem where the park brake on my right rear wheel isn't working as well as the one on the left side.
I've checked and set the adjustment. With both wheels jacked up both wheels, when turned by hand, lock at the same number of clicks when you pull the park brake handle. Yet if you apply the park when you're rolling slowly on gravel or even on smooth hotmix only the left wheel can be made to lock up. Since both wheels lock at the same point when turned by hand I would have expected them to give similar results.
Pads look to be equal both sides with plenty of meat left, as you'd expect since they only get used for the park brake.
Any suggestions? Cable stretch on the R/H side?
