parker lights problem
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Macka21, Jan 17, 2009.
  1. Macka21
    Macka21 New Member
    Whyalla S.A
    CAMMED VY SS Series 2 M6
    hey guys bought some blue led globes to put in my parkers but they didnt work??? but no with my normal parker globes in there they still dont work... can anyone help?
  2. LightningVP
    LightningVP Donating Member
    VY II 5.7 SV8
    LEDs have a certain way they need to go in, either the globes don't work or you put them in the wrong way, try turning them around and see if they work :D
  3. Flat_White
    Flat_White Banned
    Rolls Royce "Fantom"
    yep exactly what he said ^^^^^
    regards,
    -Whiting
  4. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    On the VY base models, the long mounting tube for the parking light has to be inserted the right way around, too. It is quite possible to insert it the wrong way up and it feels as though it is correctly in place, when it's not. Have a look at the tube before you try to fit it to the headlight - you will see a marking to indicate which way is up.
    Even with the standard globes, if you don't get this right, the lights won't work.
  5. Macka21
    Macka21 New Member
    Whyalla S.A
    ok then cheers blokes i put purple led in there will post pics of them at night
