Part Number Holden VZ V6 LE0 02 Sensor - Solved
scaredyet
44
Mosman
Holden VZ Lumina Wagon
UPDATE:
Got the part number from Holden. I only need two for my vehicle and both are the same. I ended up buying the Bosch from eBay. Hope this helps someone.
Hi guys can someone direct me to the part number for an 02 Sensor for the VZ?
My bank 1 is apparently not good I'm getting 14.4L/100km so I want to change them both.
I know my car has only 2. Are both 02 sensors the same?
Can someone confirm this is the correct part? Are these genuine? They seem cheap
Fu Manchu
Get Off Your Phone When You’re Driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8 (VE Calais)
For an 04/05 or a 06/07?
scaredyet
44
Mosman
krusing
[/URL]
Being Bosch, and both for that price,
Thats not to bad.
But is it the Sensors ?
scaredyet
44
Mosman
Well the car was at the mechanics for a seperate issue.
I asked the mechanic if he can find vacuum leaks and if he had a smoke machine. I mentioned the bad fuel economy. He said he will plug the scanner in and see what the fuel trims say. He then said something about the 02 sensor bank one but then said to be sure you will have to change them around to bank 2 to see if it gives the same problem. He didn't want to throw parts at it so I said not to worry.
I have a toolpro obd scanner. Can I plug it in to see what's going on with the 02 sensors
greenacc
Searching for the billion
VE Berlina
You need to check what the plug looks like on your O2 sensors. There are at least 2 types. One has the plug with the red rubber ring and the other has a different plug like this.> So check before you buy.
Fu Manchu
Western Australia
That one is precat 06/07
scaredyet
44
Mosman
