diysv6
- Dec 17, 2005
- 547
- 28
- 28
- Location
- SEQ
- VF S1 SV6 STORM A6: VZ S1 SV6 A5
Hello all,
The passenger side rear door window glass is randomly opening 50 to 75mm without any button operation. (2015 VF Sedan)
I am looking for a heads up for the condition if possible, before I pull door skins, lift carpets etc..
I don't think the power windows are controlled by any computers, so the issue could be a pinched wire somewhere in the drivers door control box wiring loom, body wiring or a dodgy switch in the drivers door control box or in the rear door window switch itself?
Are the window winder electrical mechanisms prone to "mechanically" slipping from the closed position?
The window glass opens and closes smoothly without any grinding, slipping etc. .
Wife thinks she heard the window motor operate once as I getting out through the driver front door. (Ignition keys in hand).
It has happened three times but is not predictable.
I tried opening and closing doors, ignition on/off, ignition key out, in various combinations, but I could not bring on the condition
Anyone had this issue?
Thanks in advance for any suggestions.
