Passenger seat wiring disconnected.
Tripxit
56
VF SSV Redline Wagon
Anyone know what this wire is for in the picture?
I'm thinking maybe seat side airbag? Not sure if it's been disconnected or come apart by someones feet.
There is a tag on it but doesn't say anything other then a few numbers.
Philmecrackun
Lismore
VFII Calais V 6.2L 1972 Ford Galaxie Wagon 400ci
Do you have heated seats?
3rspecB
VF2 SSv Redline, White Manual Sedan
Looks like Butt on seat sensor. If airbag related, you would get an airbag light come on in your instrument cluster.
M
mwb235
Guest
It might be the passenger seat occupant sensor i.e. if someone sits in seat without seatbelt on a chime will sound, and it tells the car what airbags are needed in a crash (I think). It's a small thin plastic sheet with some conducting surfaces in it, attached to the base seat foam (between foam and seat trim).
Edit: just saw 3rspecb's post, beat me to it.
Tripxit
56
Thanks guys, I'll checkout the sensor thingy. Didn't think of that.
Skylarking
123
Downunder
Commodore Motorsport Edition
I thought all airbag cabling was shielded while all airbag connectors were a real pain to separate.
I believe it was done like this, specifically so one can't inadvertently pull things apart, you need technique and persistance to get such connectors apart.
stooge
wa
Turbo Alpaca
no they are just like any other plug, you can unplug an airbag with ease.
the handsfree mic in the roof is harder to unplug than the airbags :confused:
VS 5.0
Probably coz less handsfree = more airbag.
ChRiDDa
N/A
VE SS-Z Sportwagon
As others have said, it’ll be for the sensor that chimes should someone sit in the seat without their seatbelt on
All the airbag connectors will be colour coded in yellow
