Hi...After replacing passenger power side mirror the the passenger side windows only goes up halfway. After checking if anything in the mirror was preventing the window from going all the way up I removed the mirror and the window still had the same problem. All the other windows work fine. Any suggestions Thanks John from Warragul
How much did you tighten the bolt that holds the window track in? These tracks are made of very shitty aluminium and the bolts will just keep threading through and push through the aluminium which will cause bumps in your window track.
Thanks for replying. I took the mirror off after finding the problem with the window and the window still won't go all the way up. John
