PC dead. MoBo or power supply?
Discussion in 'The LAN Lounge' started by Troy711, Jul 19, 2011.
  1. Troy711
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    I went to use my computer last week and it's usually left switched on but this time it was off. I tries the switch to no avail and I checked all the connections and they were fine. I assume it's either the power supply or the mother board. Is there any way to check or am I just better off taking it in to get fixed?
    Cheers.
  2. Super_Low 91
    Super_Low 91 ┌∩┐(◕_◕)┌∩┐
    Aussie
    Not a Commodore
    Try this, I follow these steps every time i want to fault test a system that doesn't boot,
  3. Troy711
    Canberra, ACT
    Try what..?
  4. lsvys
    lsvys New Member
    Sydney!
    VY S
    Does it actually turn on and POST Troy? Or just not power up at all?
  5. Troy711
    Canberra, ACT
    Nope, you hit the switch and it's totally dead.
  6. lsvys
    lsvys New Member
    Sydney!
    VY S
    Sounds like the power supply - do you have a old PC with a spare PSU that you could wack in to test it??
  7. Troy711
    Canberra, ACT
    I do but it doesn't have the right plugs for the hdd or cd drive.
  8. Astranomical
    Astranomical Ecotec just kicked in yo
    Dee Why, NSW
    Hammerhead Eagle i-Thrust
    Don't worry about that for now, you don't need the drives connected for the machine to POST and come up with the BIOS boot screen. As long as its powerful enough for the parts in your system, and so long as it has all the correct connectors (which it may or may not depending on the age, power supplies made prior to 2005 will usually have a 20 pin ATX connector, rather than the 24 pin connectors used in most systems today, and power supplies made prior to 2002 will not have an ATX12V connector (the smaller 4 pin connector with the yellow and black wires that is separate to the main ATX connector)
  9. lsvys
    lsvys New Member
    Sydney!
    VY S
    I don't think I could have said that better!!
    Only other thing I might mention, make sure everything is plugged in internally..
  10. Troy711
    Canberra, ACT
    Cheers, I'll give it a go and see what happens. I'll post back with results.
  11. XStatic64
    XStatic64 ^^
    Adelaide, SA
    00' WH Stato LS1 A4
    Sounds like PSU, but.... take the ATX connector off from the motherboard, grab a paperclip and put it into the green and any of the black earth wires. This should turn the psu On, and you can put a multi meter on the other pins to check if its live, or just ensure that the psu is ON ( see if the internal fan is spinning).
    Also, many motherboards have internal power buttons on them, mine does (power + reset). try hitting one of these to see if it powers on.
  12. MikeCuzzy
    MikeCuzzy Jumping puddles
    Australia
    2007 VE Omega 3.6L
    My guess is PSU, though it could be both. I.e, PSU blows and then takes mboard with it, I've had that before.
  13. 50LTRv8
    50LTRv8 Member
    VT V8 Calais
    Hey Troy, if you want me to have a squiz at this let me know, I only live round the corner
  14. NV-MY-VT
    NV-MY-VT Sleeper Builder
    Mornington, Victoria
    VT 2000 Olympic Edition
    It's gotta be the PSU... Or even just the power button.
