pcm difference
hitman1979
Alice Springs NT
VE SV6
can anyone tell me will a VN manual PCM fit into a VR and work with the body control module being that the VN's dont use body control modules
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
if its a vr manual and you just want to run the engine yes it will work but if you put the vr chip in it wont run cause it wont get the request from the BCM to turn off the security as the 808 vn ecu doesnt have the uart comms chip for the highspeed aldl.me or foam can soon do a chip without the security active to get round that if needed.plus you wont get errors reported from ABS etc with the 808 ecu
