Berlina&Jag guy
- Jun 29, 2019
- 21
- 24
- 3
- Age
- 51
- Location
- Sydney
- Vz Berlina Wagon
Shortly after doing a service on my 06 alloytec the check powertrain warning came up and so I used a cheapo OBD2 dongle to find the fault and got a reading of P0105: Manifold Absolute Pressure/ Barometric Pressure Circuit.
Most people seem to say that this usually indicates a vacuum leak and sure enough the main PCV hose/ rigid pipe setup was broken. This is the one that comes off the top rear of each rocker cover and joins to a T that has a short corrugated pipe which connects to I’m not sure what!!? I replaced this 3-way rig with a brand new one from Sutton’s in Homebush and was certain the problem would be solved. No chance- still same error code.
Next I noticed the little rubber elbow feeding off the throttle body at the front was basically stuffed- really soft, cracks and just hanging in there. Refusing to pay $17 from the only guy on eBay who sells them I fixed this with a short length of new hose in a looping curl so it didn’t kink. Still no fix!
I’ve read quite extensively on this forum- at 211,000km I know I’ll be up for new chains soonish and I’m aware of the left rocker cover vacuum outlet being to small and this side especially being prone to gunking up so I’m guessing my next move is to pop the rocker cover and clean the gunk and drill out the spigot/ outlet.
Does anyone agree this is the best thing to do next or maybe something else I could try first?
Could I have maybe bumped or damaged the MAP wiring when I took the manifold off to do the service?
One thing, a bit silly that I did was overfill the oil when doing the service. Stupidly I drained the old oil into a plastic pan as you do then changed the filter, new sump plug and filled up with the recommended 6.5L but when I went to dispose of the old oil I filled up an old oil container and there was only about 5L so I obviously put at least an extra litre in. This has burned off now 2,000 km later and is at the right level more or less but I wondered if this overfilling might have caused some excess oil to get in and block up the PCV system?
I would be delighted if anyone was able to offer advice or opinions here.
I was hoping to do all the easy fixes first before popping a rocker cover as obviously that involves decent time and money investment.
Also, would fitting a catch can be recommended in light of this vacuum system design fault on the Alloytec?
Thanks everyone in advance.
