phat_6ltr's not so phat 4ltr turbo Territory
Discussion in 'Miscellaneous' started by phat_6ltr, Feb 15, 2014.
  1. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    Hi all, picked up my new wheels today, an 06 Ford Territory Ghia Turbo.. Some of you might remember my previous ride, a VE SS that was fairly warmed over to say the least ;)
    I ended up selling it due to needing the extra row of seats, larger boot space and height clearance. Anyway it's gone and I must move forward.
    It's dead stock atm apart from the debunged exhaust. One of many mods to come.
    Here is the future mods list:
    -GT3582R (or bigger?)
    -Plazmaman front mount
    -60lb injectors
    -Plazmaman inlet plenum
    -3.5" dump pipe
    -3.5" single cat back exhaust
    -Transmission upgrades
    Also tossing up on some SPOOL H beam con rods, not real sure on what pistons? As is with the tranny upgrades?
    I'm a full blown virgin when it comes to Ford stuff so all you blue ovalers please feel free to chime in, all my information comes from hours of reading and a mate that owns a BF xr6t.
    My end goal is a reliable 380+awkw.
  2. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    I remember when i was driving my stato up to QLD and was putting along a country road next to one of these. they actually go like the clappers i had trouble keeping up.
  3. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    I can seriously tell u, it surprised the sh!t out of me!! For a 2t+ vehicle it hauls arse lol.. Heavy on the juice tho but nearly everyone I've spoken to that owns one says the same thing
  4. AirStrike
    91' VN SS
    It already has a 3582 on it champ. You will need something bigger for the power you want or run it on E85 with a gut full of boost and timing.
    If you want a reliable 380awkw your talking a built ZF and a built motor 100%, depending on the actual build date yours might have the BA banana rods, then start looking for a spare transfer case.
  5. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    I see, do you have a turbo size you could recommend? E85 is out of question, closest station that serves it up is over 200k's away :(
    Don't mind building the engine n box to suit, it's a win win.. Except for my wallet and missus lol
    Is there a aftermarket option for the transfer case? Haven't found to much info on this..
    What build date should I be looking for?
  6. AirStrike
    91' VN SS
    Are you looking to keep it factory looking or not? Not many options that will work with the factory manifold (at a minimum you would switch to the FG unit).
    As far as I know not many options for the transfer case.
    After October 06 they changed to the F6 items, much stronger.
  7. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    What ever works really, I was told a 6Boost high rise manifold was overkill for what I'm chasing, I showed my mate this one http://bit.ly/1f6hbWv
    Can I just buy an F6 one, will it fit?
  8. AirStrike
    91' VN SS
    F6 has the same turbo as yours, there are only two factory turbos. FG XR6T/G6ET run a smaller GT3576R, all BA/BF/Terry's and FG F6 run the GT3582R. You could prob make the power you want on a GTX3582.
  9. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    Ok, sorry for my lack of knowledge here but what's the difference the GT the GTX? The numbers stay the same..
  10. AirStrike
    91' VN SS
    Billet 11 fin wheels rather then the 6 fin cast means for the same size turbo it flows more which equals more power.
  11. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    Sweet. Just done a bit of a search on em and there's a company that supply the GTX innards, I assume it'll all fit into my turbo's housing?
  12. AirStrike
    91' VN SS
    Rear housing yes, front housing will need to be modded.
  13. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    What's the turn around on getting the housing done? Would I be better off buying a complete turbo already done? (Time wise)
    It's our only car atm and with 3 kids that sh!t don't go down well lol
  14. Heron SSV
    Heron SSV Active Member
    Central Coast
    Wheres the pics man! Keen to see how nuts you go with it
  15. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    Only got the one pic atm. Lol.. Gould get it crackin lol enough
  16. AirStrike
    91' VN SS
    Find a blown turbo cheap to use for the compressor and exhaust housings.
  17. phat_6ltr
    phat_6ltr Member
    muswellbrook
    2007 VE SS M6
    Had a bit of a search today on the usual sites and there's not much in the way of blown/cheap turbos. Might do some searching at some wreckers or post a classifieds ad in the other forums.
