Plastic cover on drivers seat electric controls broken
Lordgeoff
70
WH V8 Caprice 2002
The plastic cover on the driver seat electric controls is broken. How do Inget a replacement
WH CAPRICE V8 2002 model.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
I doubt that you would be able to get a new one from Holden but you could try, failing that a wreckers or ebay would be your best bet.
figjam
Donating Member
Far Kurnell
FJ
Called a 'cover front outer' part # 92140873.
If it is just the plastic clips that attach it to the frame broken, well placed self tappers are a cheap, and hardly noticeable fix
RiffRaffMama
SW Vic
Twin VX II Berlinas - "Vanessa" and "Geraldine"
Bay 13
Dandy
VT.
They break away because of the bottom seat foam base is stuffed, once the side wings tear it then spreads and breaks off the side trim. Last I looked Ebay sold them for about 80.00
vr304
Auckland, New Zealand
2007 ssv manual
Someone like Holmart might have a new one still, I think it was them I got a new genuine one for my ve from
Whiteshark68
Queensland
VY Berlina Series II
Not exactly true they can also break if you sit on the outside edge of the seat both mine in the vt i had before the vy broke in that exact way.
after pricing them new at holden and yes they were still available new but at nearly $200 each i said nope and fixed them myself.
