Ethel
hi
With every opening of the driver door the plastic strip is catching on the wheel arch panel and making a dreadful cracking sound. After each crack the strip is increasingly peeling away.
how do i re-adhere the strip? is there a special kind of double sided tape i should be using? i also assume the existing adhesive would need to be cleaned right back with something.
thank you
thank you
